Snap-through buckling results
Vladimir_Gantovnik
Vladimir_Gantovnik Altair Community Member
Guys, I have two snap-through buckling examples: 1) panel loaded by SPCD, 2) panel loaded by pressure. In the first example, I request SPCFORCE, and then make nice plot SPCFORCE vs Displacement for center node using HyperGraph (see the image). But I don't understand what force should I use to show span-thru in the seconds example with applied pressure. Please, help me.
Answers
  • Hi Vladimir,
    you can request OLOAD output and use the applied forces computed from the pressure to plot the graph.
    Hope this helps.
    Alberto
Welcome!
Welcome!
