Hello programming experts, is it possible to use a TCL script to create the model based on the layout of the "cu" shown in the image?
Hello @asdfsdfasdfasdfasdf ,
May I ask you to elaborate? What would be your inputs (should it be the picture above), and what would be the outputs?
Best Regards,
Michael
I know that PCB layouts consist of multiple layers. Each layer can be treated as a homogenized material, with only the copper portions modeled accurately.
hello again,
thanks for your feedback. However I need to ask again, what would be your entry point: would it be a picture, a CAD file in HyperMesh, …?
And what do you want as an output: is it a CAD or a FEM file with only the copper lines?
Give me some time to gather the files, and I will explain my purpose to you afterward.
Join us for a community conversation on Pulse Width Modulation (PWM), a fundamental technique in electric motor control, and explore how different PWM strategies can yield significantly different results. This webinar provides a comparative analysis of various PWM methods and their effects on motor efficiency, torque…
Join us for a community conversation to discover the Advanced Iterative Solver(AIS) in Simcenter Feko and its application to electrically large and computationally demanding electromagnetic models. The session will provide a general overview of how iterative solution methods can help improve efficiency of large scale…
