The attribute 'total' is missing in the input example set.
![mgrabczewski](https://us.v-cdn.net/6038102/uploads/defaultavatar/nLP0QHCLH24WL.jpg)
I'm trying to sort the output of 'Wordlist to Data' by the 'Total' column. However, the 'Wordlist to Data' operator doesn't have an example set. The sorting works, but this error keeps popping up and causing issues for me.
Best Answer
So the pop-up is because the metadata hasn't reached that operator, so it doesn't know there's an ExampleSet there. What I can suggest is that you enable this option:
After the first run, it should then stop producing this pop-up. I will also investigate whether there's any other options.
Best,
Roland
1
Answers
Hi @mgrabczewski,
Just so I'm understanding the problem correctly, the issue is that you get this pop-up before running the process, but the process runs successfully?
Thanks,
Roland
0 -
Yes, process works very well, but I wonder if the pop-up can be somehow removed for visual reasons.
0 -
Best,
Roland
1 -
Great! That's exactly what was needed!
Thanks,
mgrabczewski0
