1 - 4 of
41
So the pop-up is because the metadata hasn't reached that operator, so it doesn't know there's an ExampleSet there. What I can suggest is that you enable this option:
After the first run, it should then stop producing this pop-up. I will also investigate whether there's any other options.
Best,
Roland
1 - 1 of
11
Best,
Roland
Hi @mgrabczewski,
Just so I'm understanding the problem correctly, the issue is that you get this pop-up before running the process, but the process runs successfully?
Thanks,
Roland
