1 - 4 of
41
how can i find dynamic stiffness valve between 200-300hz using (acceleration vs frequency) curve and dynamic stiffness curve plot in hyper graph.
Example:
using FRF (frequency response function) analysis
we plot (acceleration vs frequency) curve, frequency range: 1-2000HZ
dynamic stiffness curve plotted for 180kgf/mm
but my desire is to find the dynamic stiffness valve between 200-400HZ
is there any way to calculate the value in hypergraph for the desired range??
1 - 1 of
11
OS already outputs dynamic Stiffness.
try this discussion if you need to derivate it in HG:
https://help.altair.com/hwsolvers/os/topics/solvers/os/kdyn_io_r.htm
