Hi Horacio
Are you using this link to download the coupling: https://community.altair.com/community/en/altair-edem-coupling-for-ansys-fluent-with-combustion?id=kb_article&sysparm_article=KB0117663
There are multiple links, so I wanted to make sure you had the correct one.
Hope this helps.
Thanks,
Jerrin JobHi There:
Downloaded the builder using the passed link.
Still having these errors when trying to coupled EDEM 2022.2 with Fluent 2024R2 with VS2022.
CParticleData.cpp
Error Detected
=================..\..\src\compute_particle_forces.c(53): error C2198: 'Path_Status init_tracked_particle(Tracked_Particle *,Particle *,cxboolean,cxboolean,cxboolean,cxboolean)': poucos argumentos para chamada
..\..\src\compute_particle_forces.c(185): error C2198: 'Path_Status init_tracked_particle(Tracked_Particle *,Particle *,cxboolean,cxboolean,cxboolean,cxboolean)': poucos argumentos para chamada
..\..\src\compute_particle_forces.c(306): error C2198: 'Path_Status init_tracked_particle(Tracked_Particle *,Particle *,cxboolean,cxboolean,cxboolean,cxboolean)': poucos argumentos para chamada
EDEM-Fluent Coupling Error
Answers
Hi, I have the same error. How do you solve this error?
0 -
Hi, which version of EDEM and Fluent are you using? For the coupling compiler which version of this do you have?
Regards
Stephen
0 -
I'm having the same problem, I'm using FLUENT2024 and EDEM2024, VS2022.
I have explored the situation a bit and will now recount some of my findings as follows, I first looked at the error where it was reported suggesting missing parameters, but the nearby lines where init_tracked_particle was called with 5 parameters and also with 6 parameters made me very confused and tried to find the relevant declarations for the init_tracked_particle function. particle function.
Luckily, I managed to find it, the declaration is located in the dpm_mem.h file in the fluent/fluent24.2.0/src/dpm folder, about init_tracked_particle near line 234, as follows
FLUENT_EXPORT Path_Status init_tracked_particle(
Tracked_Particle *tp,
Particle *p,
cxboolean unsteady_tracking,
cxboolean update, cxboolean need_cp, cxboolean need_cp
cxboolean need_cphase, cxboolean is_tracking, cxboolean is_tracking
cxboolean is_tracking_tp_P
I found that comparing it with the previous version pairs a parameter of type cxboolean is_tracking_tp_P, in the previous declaration there were only 5 parameters. So I tried to add parameters to the init_tracked_particle function on lines 53, 185, and 306, and the one I chose to add was TRUE, and my coupling proceeded successfully
Here are some things I don't understand about what exactly this parameter means. What is the effect of me setting it to TRUE? What is the official recommended setting? I didn't find the parameter online, and with the help of ai, it tells me that this parameter indicates whether or not the particles in Tracked_Particle are being tracked. If TRUE, it means that the current operation is directly related to the Tracked_Particle, possibly initializing or updating a specific tracked particle.
But I'm still not sure what effect this parameter will have on my coupling, and am rather confused as to how many other places use the init_tracked_particle function, many of which also just enter 5 parameters, why they don't report an error, and whether there is a default value for the 6th parameter for those that don't report an error? Is there a default value for the 6th parameter that is not reported? Do we need to add a specific parameter for it?
I hope you guys can help me with this function and tell me how I can change the parameters of init_tracked_particle!0 -
Particle *p,
