what is mean grid Value in result data.
User: "HK2204"
Altair Community Member
Result show some grid number , numbers what is desfine in result.
1 - 5 of 51
    Hello @HK2204 ,
    Grid is same than Node
    Hope that helps,
    Michael
    User: "HK2204"
    OP
    what is meaning of Grid value ?
    value ,what is represent in result data?
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello again,
    You applied a nodal contour in HyperView (displacement, stress averaged on nodes, …). Then max xx at grid yyy means that for this contour, the max is xx, and is located on node yyy.
    hope this helps,
    Michael
    User: "HK2204"
    OP
    Value defines location of node or Node Number ?
    hello,
    that depends what you plotted as result in HyperView. If you plot a displacement,value is the displacement for this node. If you plot an average stress result, then value is average stress at this node.
    But the picture you sent first doesn't expose what is plotted here.
    Best Regards,
    Michael
