ERROR:Not enough memory
ZXG
ZXG Altair Community Member
Hi!I am using Optistruct to conduct a transient NVH simulation, there's an error: "Not enough memory. (error code -2)". My run option is "in-core, -nt 18".
As you can see, the “.Out” file shows Estimated Memory (RAM) for In-Core Solution is 85002 MB and my computer has enough memory(248073 MB RAM) .
Could you please advise what should I do? Simplify my model or choose “-core(out/min)” run option? Thanks a lot!
324bf8b8c9645fab0712f27f6278a7a.png 8566a2cdcfb695c74b286cfcd0bcac8.png 0a38e6988d302087c0dffb332229d8f.png
Welcome!
Best Answer
  • Rajashri_Saha
    Rajashri_Saha
    Altair Employee
    Answer ✓
    You can try both, -core out as well as having coarse mesh simplified model.
    Even reducing the output also helps.
    Can you upload the complete .out and .stat file to check few details?
Answers
Welcome!
Welcome!
