Altair RISE
Nominate Yourself Now!
Does Generative Models Qdrant Vectorstore use GRPC API rather than REST API by default?
User: "fangkuoyu"
Altair Community Member
Updated by Jocelyn
I have tried a process with two operators, i.e., "Retrieve" operator and "Get Collections (Qdrant)" operator. But,
- the process is ok under "docker run -p 6333:6333 -p 6334:6334 qdrant/qdrant:latest", and
- the process is failed under "docker run -p 6333:6333 qdrant/qdrant:latest" (the error message is _InactiveRpcError: _InactiveRpcError of RPC that terminated with: status = StatusCode.UNAVAILABLE, details = "failed to connect to all addresses; last error: UNAVAILABLE: ipv4:127.0.0.1:6334: Connection refused")
According to the document of Qdrant on https://qdrant.tech/documentation/quick-start/, REST API uses port 6333 and GRPC API uses port 6334. Does Generative Models Qdrant Vectorstore use GRPC API rather than REST API by default? Can we use REST API for accessing a local Qdrant server?
Thanks
Frank
1 - 2 of 21
    User: "anush"
    New Altair Community Member
    Accepted Answer
    Hi. RapidMiner does use Qdrant's GRPC interface, which defaults to port 6334. The connection params are "uri' which can be set to the GRPC address and an optional "api_key".
    User: "fangkuoyu"
    OP
    anush
    Thanks for your comment.
    Frank
