there are two operators i am getting errors
Booram
Booram New Altair Community Member
edited November 2024 in Community Q&A
when using the process for the Amazon Stock Price Prediction - Problem Statement and Materials, there are two operators with errors. see screenshot with red errors. I would also appreciate an explanation for what the output is telling me, that is not provided anywhere. I am attaching the csv file and .rmp file for your reference.
Welcome!
Answers
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    what happens if you right click on the operator and use the Show Problem option?
    BR,
    Martin
  • Booram
    I am attaching the screenshot for those two operators the message that shows . please help with this issue as soon as possible
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi @Booram ,
    so what exactly is unclear about the error messages? They seem very straight forward?
    Cheers,
    Martin
  • Booram
    Okay but how to change that data type,  can you please try running the workflow and from your end provide a workflow without any error.
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    there are operators like Parse Numbers or Nominal to Numerical etc. They are in the folder Type Conversion in your operator tree.
    Cheers,
    Martin
  • Booram
    Okay thanks for your response i will check it and get back here if it doesn't work
Welcome!
Welcome!
