operators
nn_here
nn_here New Altair Community Member
edited November 2024 in Community Q&A
Hi,
Can you please let me know in rapidminer which operator can be used to pull data from an external source(like websites or so).I tried with the operators extract structured data and search webhose.io,but those didnot help.
Welcome!
Answers
  • ClaudioKeck
    ClaudioKeck
    Altair Employee
    Have you tried the Webmining extension? there are possibilities to use different http based get requests.
  • nn_here
    Thank you for providing the help. But sorry i am unable to get it.
  • ClaudioKeck
    ClaudioKeck
    Altair Employee
    https://marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_web have you tried and installed this extension? In This extension are operators which allow you to get data from REST APIs or Websites in case this is what you are looking for, otherwise could you please explain in more detail what you want to get data from?
  • nn_here
    Hi, yes i have installed this and tried using the operator 'crawl web'.
    But the process has failed with the errors as given below.
    • Exception: java.lang.NoClassDefFoundError
    • Message: org/apache/tika/parser/html/HtmlParser
    • Stack trace:
    • edu.uci.ics.crawler4j.parser.TikaHtmlParser.(TikaHtmlParser.java:34)
    • edu.uci.ics.crawler4j.parser.Parser.(Parser.java:42)
    • edu.uci.ics.crawler4j.crawler.CrawlController.(CrawlController.java:85)
    • com.rapidminer.operator.web.crawler.CrawlerOperator.doWork(CrawlerOperator.java:269)
    • com.rapidminer.operator.Operator.execute(Operator.java:1024)
    • com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
    • com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:804)
    • com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:799)
    • java.base/java.security.AccessController.doPrivileged(Native Method)
    • com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:799)
    • com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
    • com.rapidminer.Process.executeRoot(Process.java:1476)
    • com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1452)
    • com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
    • java.base/java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
    • java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(Unknown Source)
    • java.base/java.util.concurrent.ForkJoinPool.scan(Unknown Source)
    • java.base/java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
    • java.base/java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
    Would be great if you could assist me in getting this issue resolved.
    Thanks in advance.
  • ClaudioKeck
    ClaudioKeck
    Altair Employee
    Could you share the process you tried to use please?
  • nn_here
    Hi,Kindly find the attached document containing the  screenshot of the process that  has been run.
    Thankyou.
  • ClaudioKeck
    ClaudioKeck
    Altair Employee
    This will be fixed. in the meantime here a workaround which should work: <?xml version="1.0" encoding="UTF-8"?><process version="10.3.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
    <operator activated="true" class="web:crawl_web" compatibility="10.0.000" expanded="true" height="68" name="Crawl Web 5.X" width="90" x="246" y="187">
    <parameter key="url" value="https://altair.com/"/>
    <list key="crawling_rules"/>
    <parameter key="write_pages_into_files" value="true"/>
    <parameter key="add_pages_as_attribute" value="false"/>
    <parameter key="output_dir" value="C:/"/>
    <parameter key="extension" value="txt"/>
    <parameter key="max_pages" value="100"/>
    <parameter key="max_depth" value="1"/>
    <parameter key="domain" value="server"/>
    <parameter key="delay" value="1000"/>
    <parameter key="max_threads" value="1"/>
    <parameter key="max_page_size" value="500"/>
    <parameter key="user_agent" value="rapid-miner-crawler"/>
    <parameter key="obey_robot_exclusion" value="true"/>
    <parameter key="really_ignore_exclusion" value="false"/>
    </operator>
    <connect from_op="Crawl Web 5.X" from_port="Example Set" to_port="result 1"/>
    <portSpacing port="sink_result 3" spacing="0"/>
    </process>
    </operator>
    </process>
  • nn_here
    Hi, Thankyou for the reply given .But Iam afraid it is not working as i am getting the same error. Kindly find the screenshot regarding the same.
  • nn_here
    Hi,Please find  the attached screenshot of the mentioned error.
  • nn_here
    Document.
  • ClaudioKeck
    ClaudioKeck
    Altair Employee
    Hi we rolled out Web Mining Extension version 10.0.1 which should fixed the issue
Welcome!
Welcome!
