🎉Community Raffle - Win $25
Join and Win
RapidMiner 9.10 cannot run process as it is unable to find data file.
User: "yajurveda"
New Altair Community Member
Updated by Jocelyn
When attempting to run a process, I get the following error "Cannot retrieve data from entry ../../../Data/Classification/<< file name >>'. Reason: Entry //LocalRepository/Data/Classification/<< file name >> does not exist. The repository did not deliver the requested data."
I checked, double checked, triple checked the file location and file itself, can import the data as well. Why is my process unable to find?
1 - 4 of 41
    Hi @yajurveda,
    What type of file are you trying to retrieve? And which operator are you using?
    Best,
    Roland
    User: "yajurveda"
    OP
    I was able to resolve this. Looks like the process was looking for the data one level above the Local Repository directory.
    Sounds great! Just so you know, you can drag and drop from the repository into the process window, so the file path would be sorted automatically.
    Best,
    Roland
    User: "yajurveda"
    OP
    Thanks Roland! This is a very helpful tip! Will try that if I run into similar errors in the future.
