🎉Community Raffle - Win $25
Join and Win
RapidMiner launching error
User: "krisz86"
New Altair Community Member
Updated by Jocelyn
Dear Community,
Every time I try to launch RapidMiner I get this error:
I tried everything which is this question:
https://community.rapidminer.com/discussion/comment/186148/#Comment_186148
Can anyone help?
Thanks,
Krisztian
1 - 5 of 51
    User: "Caperez"
    User: "krisz86"
    OP
    Yes, and it did not help.
    Hi @krisz86 ,
    This looks like it could be potentially caused by the uninstaller failing to fully remove the previous version. You can either try installing again (you might need to try this a couple of times), or manually delete the installation folder to ensure it's empty before installing.
    Hope this helps.
    Best,
    Roland
    User: "krisz86"
    OP
    Dear Roland,
    I have tried that as well several times and it as also not working.
    I deleted the folder manually as well and nothing happened after, I still got the same error.
    Best,
    Krisztian
    Hi Krisztian,
    Could you show us the errors you get when starting the .bat file? Just as it might help in debugging further what the root cause is.
    Thanks,
    Roland
