Need help with generating word cloud under visualizations/graphs. I have the process correctly defined and generating output table but having issues with visualization.
Wordcloud cannot support more than 500 distinct values - is there a chance you've exceeded this? However, there should be a clear error at this point anyway. Are you facing issues with any other visualization types?
The data is filtered to only obtain first 500 words. No error and wordlist are produced. Just not able to use word cloud visualizations. Bar graphs etc. are displayed under graphs and it works fine.
Would it be possible for you to share the data sample? Just want to rule out an anomaly there before we investigate further with the software. Alternatively, I will find a sample for you to test
Thank you. I imported the dataset in RapidMiner and tried the visualization but "wordcloud" is not an option in the plot. I have RapidMiner Studio 9.10.013 education edition. Could this be the problem? Do I need a higher version or require extensions?
Figured out the problem finally - Laptop zoom-in/scaling prevented me from scrolling down the list of all available graphs in the plot window. Word cloud works now based on the example you had shared. Thank you very much for your support and help in resolving this issue.
Best,
Roland
