Sir, here i am attaching you the FEM file and .out file
sir its showing fata error occured ERROR: 3865
the error #3865 is due to SPoint having the same ID as an existing Grid (node). Try changing IDs so they don't overlap.
https://community.altair.com/community?id=community_question&sys_id=7f96847a1b2bd0908017dc61ec4bcb2d
i changed still i am getting the same error
please check and help me with this
now i rectified the error but now this is the error i am facing previously,
so my doubt why Hex mesh is not solving in optistruct. and then i tried to change into Tet mesh and solved, the model is solving
the problem is with Hex mesh? why? please help me with this sir @Prakash Pagadala @Ivan @Rahul R
You should to switch the SPC to ASET card
The rigids element needs to be switched to rbe2
and also previously i used to have my models with same ID at that time they got solved, now i am facing the error
Please share .out file of the run.
