Why hex mesh is not solving in Optistruct?
when i am trying to solve its showing some error.
can you please help me with this.
Awaiting Reply
thank you
Please share .out file of the run.
Sir, here i am attaching you the FEM file and .out file
Material Property is not assigned to the elements. Please assign same and run again.
sir you mean to say in Component section ALL ELEMENTS??
yes.
sir its showing fata error occured ERROR: 3865
Hi @LOKESH KATARI
the error #3865 is due to SPoint having the same ID as an existing Grid (node). Try changing IDs so they don't overlap.
i changed still i am getting the same error
please check and help me with this
and also previously i used to have my models with same ID at that time they got solved, now i am facing the error
now i rectified the error but now this is the error i am facing previously,
so my doubt why Hex mesh is not solving in optistruct. and then i tried to change into Tet mesh and solved, the model is solving
the problem is with Hex mesh? why? please help me with this sir @Prakash Pagadala @Ivan @Rahul R
You should to switch the SPC to ASET card The rigids element needs to be switched to rbe2
