I am getting error of Process failed: Wrong input of type 'Data table' at port 'example set input'.
1 - 2 of
21
Hi @DR01K, it looks like you might be using the Select Attributes (In Database) operator. Could you try the standard Select Attributes operator and see if that works?
Hey @DR01K, could you please explain what you're trying to to in the first place? Using write CSV inside a In Database Nest to change something into nominal seems like a strange workaround for something. Let's try to find a solution to your original problem.
