🎉Community Raffle - Win $25
Join and Win
Linux installation failure
User: "MRWood"
New Altair Community Member
Updated by Jocelyn
Hi
I am trying to install RapidMiner 10.2 on Linux ( Fedora offshoot).  I have installed the latest Java as per the installation instructions.
java version "20.0.2" 2023-07-18
Java(TM) SE Runtime Environment (build 20.0.2+9-78)
Java HotSpot(TM) 64-Bit Server VM (build 20.0.2+9-78, mixed mode, sharing)
[mark@nobara-linux rapidminer-studio]$
After running the .sh file i saw the first dialogue screen asking to choose a licence path, but on selecting the RapidMiner option the
RAPIDMINER_HOME is not set. Trying the directory '/home/mark/Downloads/rapidminer-studio'...
WARNING: package com.apple.eawt not in java.desktop
WARNING: package sun.lwawt.macosx not in java.desktop
Aug 22, 2023 11:06:55 AM com.rapidminer.tools.PlatformUtilities logInfo
INFO: Searching in Java classpath for RapidMiner Studio jars...
INFO: Trying parent directory of '/home/mark/Downloads/rapidminer-studio/lib/rapidminer-studio-core-10.2.0.jar'...
INFO: Gotcha! 'rapidminer.home' is: /home/mark/Downloads/rapidminer-studio
INFO: Release platform: ANY
Exception in thread "main" java.lang.UnsupportedOperationException: The Security Manager is deprecated and will be removed in a future release
       at java.base/java.lang.System.setSecurityManager(System.java:429)
       at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:920)
       at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:333)
Any pointers would be appreciated
Thanks
1 - 2 of 21
    User: "jwpfau"
    Altair Employee
    Accepted Answer
    Updated by jwpfau
    Hi,
    you need Java 11 to run RapidMiner Studio 10
    sudo dnf install java-11-openjdk.x86_64
    Maybe you also have to run
    sudo alternatives --config java
    afterwards
    Greetings,
    Jonas
    User: "MRWood"
    OP
    Accepted Answer
    Thanks Jonas, I was already running java 17 so have downgraded to 11.  Assumption was that the latest version would work the same.
