Get the "wei" from Decision Tree within a Split Validation Operator
Hello,
Currently, I have a simple model with a decision tree that looks like this:
In my Split Validation, currently I have the following operators:
I want to get the "wei" from my decision tree, so that I can see the Feature Importance Table in the Results.
I tried this way:
But it is throwing an error when I run it:
Do you recommend any workaround?
Thank you!
I tried this way:
Thank you!
1 - 4 of
41
I don't think it would be because of the dataset... If I tried to get the "wei" from the decision tree outside the split validation operator I would be able to see the Feature Importance Table in the results.
@BalazsBarany, your suggestion worked. Thanks a lot!
By the way, is there any way I could also retrieve the parameters that I am setting in my decision tree?
I used the SPLIT VALIDATION sample in Rapidminer and the successfully generated the weights. It may relate to your dataset. Perhaps share the .rpm and data files? hth
