Segmentation Fault in Starter
Hi,
I'm trying to benchmark a m/c with a Radioss model. I have run simple jobs on it OK but when I try to use more complex jobs the starter module fails with a segmentation fault. The model I have been given has run on other machines.
I have tried other, larger models (downloaded from the Altair website) and a similar thing happens only earlier in the data check process.
Has anyone had a similar experience?
Thanks
I would like to open this thread again, since I am having a similiar problem.
With one particular model of mine I keep getting a 'segmentation violation' error
a section of the output file:
The error almost seems to occur randomly, however only with one particular model so far.
Sometimes the solver runs, but mostly it doesnt.
Since I use windows I have done the settings as suggeted by the radioss user guide. (KMP_STACKSIZE = 64m).
However it doesnt seem to help.
Is there anything else I could do to fix this?
regards
Ralf
Now, keep having this problem when I try to run a HyperStudy analysis.
When I run the model file just by itself with radioss it works. However, if I want to do the nominal run in HyperStudy I get the same segmentation violation error.
What could it be?
Hi,
Have you tried dos2unix conversion? Maybe it could help. I was experincing a problem like that and dos2unix conversion helped me alot.
Another thing is keep your solver executables and c/c+ libraries up to date.
Hi
I am trying to solve an explicit problem with Radioss and having similar problem. When it comes to 'GROUPS' it gives this error and terminates the job. Any advice?
| ABNORMAL END |
| Segmentation Violation |
| TRACE BACK : |
GROUPS
ERROR id : 760
** ERROR TRAPPED
Starter STOPPED due to INPUT ERROR
Hi All,
Is there any way how to identify cause of segmentation violation error. I'm trying to run an analysis, which is similar to my previous work.
Also any possible causes for this error would be appreciated....
Hi,
I faced this error and then I transferred mirrored elements to original components and remove empty components. Problem is finished, model is solved witout any error.. If you made some mirror operation in your model, maybe it depends on that...
Hi,
what is your material and property? do you use /QUAD or /SHELL elements? /QUAD s are applicable only for 2D problems.
Regards
Rahul R
Hello RJW,
The issue is probably related to stacksize of the machine.
If you set stacksize to unlimited - the starter should run through with any segmentation issues.
If it's a linux machine, depending the shell this is how you set stacksize
in csh SHELL
to know all limits, type :
limit
To set the Stacksize to unlimited type :
unlimit stacksize
In ksh,bash,sh:
the command to know all limits is :
ulimit -a
to set the Stacksize to unlimited type:
ulimit -s unlimited
Hope this works
HWSUPPORT
