I'm trying to benchmark a m/c with a Radioss model. I have run simple jobs on it OK but when I try to use more complex jobs the starter module fails with a segmentation fault. The model I have been given has run on other machines.
I have tried other, larger models (downloaded from the Altair website) and a similar thing happens only earlier in the data check process.
Has anyone had a similar experience?
Thanks
