Filter multiple example sets with similar filteration
New Altair Community Member
Updated by Jocelyn
Hi, I have multiple example sets coming from different sources. All sources contains a common column named date. I need to put a common filter for all sources but dont have to combine them. Is there a way to use filter operator only once for all sources. Like source1 source2 source 3 passed to filter.. and we get output as output1 output2 output3
1 - 3 of
31
Hi,
don't know if this is the most elegant way but you could use Collect, Loop Collection and Multiply with n Select operators afterwards. You can do the filtering inside the Loop Collection operator.
You can also have a look at the tutorial process of the Select operator to see an example.
Greetings,
Jonas
Greetings,
Jonas
can you help here somehow
