Filter multiple example sets with similar filteration
KanikaAg15
KanikaAg15 New Altair Community Member
Hi, I have multiple example sets coming from different sources. All sources contains a common column named date. I need to put a common filter for all sources but dont have to combine them. Is there a way to use filter operator only once for all sources. Like source1 source2 source 3 passed to filter.. and we get output as output1 output2 output3
Welcome!
  • KanikaAg15
    edited May 2023
    @Mo_Abdolrahim  @MarcoBarradas @MartinLiebig
    can you help here somehow
  • jwpfau
    jwpfau
    edited May 2023
    don't know if this is the most elegant way but you could use Collect, Loop Collection and Multiply with n Select operators afterwards. You can do the filtering inside the Loop Collection operator.
    You can also have a look at the tutorial process of the Select operator to see an example.
    Greetings,
    Jonas
  • KanikaAg15
    Thanks for the response but it will again increase number of operators required.
Welcome!
Welcome!
