A new user just getting started using RapidMiner on a Chromebook
I have downloaded the zip file and tried to open the .sh extension, which I believe should enable me to view agreements and then start using the program. However; I just have script when I open this file, no other options are available to me. As you can see I am not a computer geek, can someone please help?
1 - 5 of
51
Thanks Jonas. I have just read and watched so many 'how to' guides, and I don't trust them so I haven't gone forward. The next step for me is a PC x64, I will come back to it then. Thank you so much for jumping in with some advice Jonas, much appreciated. You will see me back when I have the right unit!! Cheers, Anthony
1 - 3 of
31
Hi,
Chromebooks are not officially supported.
Since you described yourself as "not a computer geek" i would strongly advise against trying to do this.
RapidMiner Studio is a Java Application, Version 9 requires Java 8 and Version 10 Java 11.
I won't link any guides here on installing java applications on a Chromebook and i also don't have a Chromebook at hand to be able to offer any kind of support.
Greetings,
Jonas
Greetings,
Jonas
Greetings,
Jonas
