🎉Community Raffle - Win $25
Join and Win
A new user just getting started using RapidMiner on a Chromebook
AJMGiraffeUser: "AJMGiraffe"
New Altair Community Member
Updated by Jocelyn
I have downloaded the zip file and tried to open the .sh extension, which I believe should enable me to view agreements and then start using the program. However; I just have script when I open this file, no other options are available to me. As you can see I am not a computer geek, can someone please help?
1 - 5 of 51
    jwpfauUser: "jwpfau"
    Altair Employee
    Accepted Answer
    Hi,
    Chromebooks are not officially supported.
    Since you described yourself as "not a computer geek" i would strongly advise against trying to do this.
    RapidMiner Studio is a Java Application, Version 9 requires Java 8 and Version 10 Java 11.
    I won't link any guides here on installing java applications on a Chromebook and i also don't have a Chromebook at hand to be able to offer any kind of support.
    Greetings,
    Jonas
    OP
    Accepted Answer
    Thanks Jonas. I have just read and watched so many 'how to' guides, and I don't trust them so I haven't gone forward. The next step for me is a PC x64, I will come back to it then. Thank you so much for jumping in with some advice Jonas, much appreciated. You will see me back when I have the right unit!! Cheers, Anthony
    Hey Jonas,
    How are you my friend? Hope you are ok.
    So you said I could come back to you with anything else related to this message, would this be ok? I am just asking before I post out to the community, hope you don't mind.
    Thanks, Ant
    Altair Employee
    Accepted Answer
    Hi Ant,
    a new question is always the preferred way.
    Greetings,
    Jonas
    Thanks Jonas. I have just posed a new enquiry - if you see it and have any thoughts, I would really appreciate hearing them. Cheers, Ant
