Community & Support
Learn
Marketplace
Menu
Menu
🎉Community Raffle - Win $25
Join and Win
Home
Discussions
Community Q&A
Can someone help explain how to use extract LDA and Extract Sentiment in same process?
Tremiecia
User: "Tremiecia"
Tremiecia
New Altair Community Member
Feb 20, 2023
Updated
Nov 5, 2024
by
Jocelyn
My sentiment analysis is not populating in the results once i run the process.
AI Studio
Text Mining + NLP
All Replies
Sort by
Oldest
â–¾
1 - 7 of 7
1
MartinLiebig
User: "MartinLiebig"
MartinLiebig
Altair Employee
Feb 20, 2023
Hi,
can you maybe share the process you use?
BR,
Martin
Tremiecia
User: "Tremiecia"
Tremiecia
OP
Feb 20, 2023
BELOW IS THE PROCESS.
Tremiecia
User: "Tremiecia"
Tremiecia
OP
Feb 20, 2023
I know that is really incorrect. But do i have to do Sentiment completely separate? I need the LDA and sentiment.
MartinLiebig
MartinLiebig
Altair Employee
Feb 20, 2023
with this process youw ill get 2 results. One with the topics of LDA and one with the sentiment score. I do not understand the problem?
You can of course join the two tables on an ID if you need one table.
Best,
Martin
Tremiecia
User: "Tremiecia"
Tremiecia
OP
Feb 20, 2023
Hi Martin,
the Sentiment results are not though only the LDA results show
Tremiecia
User: "Tremiecia"
Tremiecia
OP
Feb 20, 2023
It worked, i figured it out thank you!
MartinLiebig
MartinLiebig
Altair Employee
Feb 21, 2023
Hi
@Tremiecia
great - what was the trick?
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
Groups
Best Of
