Community & Support
Learn
Marketplace
Menu
Menu
Home
Discussions
Community Q&A
Can someone help explain how to use extract LDA and Extract Sentiment in same process?
Tremiecia
New Altair Community Member
Feb 20, 2023
Updated
Nov 5, 2024
by
Jocelyn
My sentiment analysis is not populating in the results once i run the process.
AI Studio
Text Mining + NLP
All Replies
Sort by
Oldest
1 - 7 of 7
1
MartinLiebig
Altair Employee
Feb 20, 2023
Hi,
can you maybe share the process you use?
BR,
Martin
Tremiecia
OP
Feb 20, 2023
BELOW IS THE PROCESS.
Tremiecia
OP
Feb 20, 2023
I know that is really incorrect. But do i have to do Sentiment completely separate? I need the LDA and sentiment.
MartinLiebig
Altair Employee
Feb 20, 2023
with this process youw ill get 2 results. One with the topics of LDA and one with the sentiment score. I do not understand the problem?
You can of course join the two tables on an ID if you need one table.
Best,
Martin
Tremiecia
OP
Feb 20, 2023
Hi Martin,
the Sentiment results are not though only the LDA results show
Tremiecia
OP
Feb 20, 2023
It worked, i figured it out thank you!
MartinLiebig
Altair Employee
Feb 21, 2023
Hi
@Tremiecia
great - what was the trick?
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
