1 - 3 of
31
Hi, thank you so much for your answer. I am trying your solutions. But description of "Import Event Log" operator in the help panel tells "This operator can be used to import a ProM XES event log file. Note that only .xes files can be read." When I ignore the description and try to import csv file, I am having "import failed" warning. So, is there any operator supports to import event log data in csv file.
By the way second solution is working, but I still like to hear the solution for what I mentioned above.
David
