Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Where are Building Blocks stored?
chee_altair_com
I managed to create a new Building Block by right clicking on a subprocess, and giving the Building Block a name.
Then I go to Edit menu -> Insert Building Block.
Here I can see the named Building Block I just created, but WHERE are these building blocks located?
Why does it NOT give me a location option when I first saved the Building Block?
Thanks
AI Studio
Accepted answers
BalazsBaranyRM
Hi!
Building Blocks are XML files in your home folder. That's ~/.RapidMiner/ on Linux and probably somewhere in your Documents folder on Windows.
They are global to one user on one computer, not restricted to a project, repository or process.
If you want to share them e. g. in a server repository or project, you could for example create a template process and put the building blocks into that. Other users can then open the process and copy the building blocks they need.
Best regards,
Balázs
All comments
chee_altair_com
I've also discovered the Settings -> Manage Building Blocks.
So it looks like Building Blocks are functional entities but they must be kept globally and available to all. We cannot create a Building Block for one project or one process, rather it will be available globally once created. Is that right?
BalazsBaranyRM
Hi!
Best regards,
Balázs
chee_altair_com
Thanks for that Balazs
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
