Sentiment analysis in rapid miner
Hi! I have an excel data file with information (numbers and words) that I need to do sentiment analysis on.
I attached a few screenshots with my process (the second to last one shows all the operators I used) and the final one shows my result.
It didn't seem to work - can someone guide me when I went wrong? I don't see results of the analysis and how the customers feel.
Thank you,
on.
Thank you,
1 - 3 of
31
@ceaperez I just did and the results still look like this. Do you offer virtual tutoring by chance? I can't figure out how to get it to show a correct analysis to work.
Hi @student2022,
Best,
Cesar
In this community we will try to help you and here you have great coleagues trying to help each others.
Please be clear in your questions and share information to try to help you.
In the column "score" you have the sum of negative and positive. If the score is negative, then the sum of negative words is greater than the sum of positive words so the sentiment of the phrase is negative, and if the sum of positive words is greater than the negative ones, the sentiment of the phrase is positive .
Best,
Cesar
Best
