🎉Community Raffle - Win $25
Join and Win
How to request element failure for HILL3D properties defined in Optistruct?
User: "Mithra"
Altair Community Member
Updated by Mithra
Hello,
I'm trying to understand the failure outputs in Optistruct. I've created a simple cube model fixed at one end and transverse load on the other. MAT9ORT has been defined for the PSOLID elements and the HILL3D criteria has been selected for MATF.
I've requested the failure output in the load case but am not finding it in the output. Please do let me know if I'm missing something. Thank you in advance.
with regards
Mithra
1 - 2 of 21
    User: "RobHoglund"
    Altair Employee
    Updated by RobHoglund
    Hi Mithra,
    Can you make sure the CFAILURE output request is in the input .fem deck? Either above the subcase section or inside the load step definition.  This requests output for the failure indices for solid elements as well as composite shells.
    CFAILURE(H3D)=ALL
    The result type should read "Solid Failure Index (HILL)" when contouring in HyperView.
    Thanks,
    Rob  H.
    User: "Mithra"
    OP
    Updated by Mithra
    Hi Mithra,
    CFAILURE(H3D)=ALL
    Thanks,
    Rob  H.
    Thank you it worked. I thought the CFAILURE was for PCOMP or PCOMPG properties only.
