1 - 3 of
31
I have updated my driver. But still there is no GPU Solver in the Selected Engine box. I have a student version EDEM 2022.3 version. Is this is because of student Version?
Hi Abinesh
Thank you for that additional information.
Student version can use 2 CPU cores (maximum) and no GPU. Other limitations are the 10000 particle limit, and disabled functionality on heat transfer, field data import and coupling to other solvers.
Hope this helps.
Thanks,
Jerrin Job
Hi Abinesh
Please update your GPU driver, and it must resolve the issue for you.
Hope this helps.
Thanks,
Jerrin Job
