1 - 3 of
31
Hi @varrunm1,
your dataset is small but please check that you haven't missing values, remove the outliners and check if the distribution of observations is balanced.
Also you can work with normalized data.
That's just a few suggestions for your process.
I hope this can help you.
Best,
Cesar
Best,
Cesar
1 - 1 of
11
Hi @varrunm1,
This message is due to the decision tree operator is waiting for the attribute (label) that needs to be predicted.
for that you can use the Set Role operator and then define the label attribute.
Best,
Cesar
Best,
Cesar
Best,
Cesar
