🎉Community Raffle - Win $25
Join and Win
Getting error while using latest deep learning extension and ND4J backend extension. ND4J not active
User: "Somnath_Das"
New Altair Community Member
Updated by Jocelyn
My rapidminer version is 9.10. I have installed latest DEEP LEARNING & ND4J BACKEND extension, but while using deep learning I am getting the error ND4J NOT ACTIVE.
Please help
1 - 3 of 31
    User: "David_A"
    can you verify that the nd4j extension is correctly loaded after you have started RapidMiner?
    Navigation Bar -> Extensions -> About installed Extensions
    Best,
    David
    User: "Somnath_Das"
    OP
    Updated by Somnath_Das
    I am also not getting the options in the backend tab.   Hope the below screnshots help
    User: "sherlock"
    same here. Did you find any solution?
    Thanks!
