🎉Community Raffle - Win $25
Join and Win
Correlation Matrix - Export
sherlockUser: "sherlock"
New Altair Community Member
Updated by Jocelyn
Hello,
how can we export the correlation matrix or the pairwise table of the correlation matrix to Excel?
THANKS!
1 - 2 of 21
    Hi @sherlock,
    You can do this by downloading the coverters extension.
    Extensions | RapidMiner Studio
    It has a matrix to example set operator.
    Here is the tutorial from the help menu
    <?xml version="1.0" encoding="UTF-8"?><process version="9.10.008">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="-1"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="UTF-8"/>
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.10.008" expanded="true" height="68" name="Retrieve Iris" origin="GENERATED_TUTORIAL" width="90" x="112" y="238">
            <parameter key="repository_entry" value="//Samples/data/Iris"/>
          </operator>
          <operator activated="true" class="concurrency:correlation_matrix" compatibility="9.10.008" expanded="true" height="103" name="Correlation Matrix" origin="GENERATED_TUTORIAL" width="90" x="246" y="238">
            <parameter key="attribute_filter_type" value="all"/>
            <parameter key="attribute" value=""/>
            <parameter key="attributes" value=""/>
            <parameter key="use_except_expression" value="false"/>
            <parameter key="value_type" value="attribute_value"/>
            <parameter key="use_value_type_exception" value="false"/>
            <parameter key="except_value_type" value="time"/>
            <parameter key="block_type" value="attribute_block"/>
            <parameter key="use_block_type_exception" value="false"/>
            <parameter key="except_block_type" value="value_matrix_row_start"/>
            <parameter key="invert_selection" value="false"/>
            <parameter key="include_special_attributes" value="false"/>
            <parameter key="normalize_weights" value="true"/>
            <parameter key="squared_correlation" value="false"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="9.10.008" expanded="true" height="124" name="Multiply" origin="GENERATED_TUTORIAL" width="90" x="447" y="238"/>
          <operator activated="true" class="converters:matrix_2_example_set" compatibility="0.9.000" expanded="true" height="82" name="Matrix to ExampleSet (3)" origin="GENERATED_TUTORIAL" width="90" x="581" y="442">
            <parameter key="pairwise_list" value="false"/>
            <parameter key="symmetric_matrix" value="false"/>
            <description align="center" color="yellow" colored="true" width="126">Representation as a list of the upper diagonal of the matrix, as it is symmetric</description>
          </operator>
          <operator activated="true" class="converters:matrix_2_example_set" compatibility="0.9.000" expanded="true" height="82" name="Matrix to ExampleSet" origin="GENERATED_TUTORIAL" width="90" x="581" y="34">
            <description align="center" color="yellow" colored="true" width="126">ExampleSet representation of the Correlation Matrix</description>
          </operator>
          <operator activated="true" class="converters:matrix_2_example_set" compatibility="0.9.000" expanded="true" height="82" name="Matrix to ExampleSet (2)" origin="GENERATED_TUTORIAL" width="90" x="581" y="238">
            <parameter key="pairwise_list" value="true"/>
            <description align="center" color="yellow" colored="true" width="126">Representation as a list of all entry pairs</description>
          </operator>
          <connect from_op="Retrieve Iris" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
          <connect from_op="Correlation Matrix" from_port="matrix" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Matrix to ExampleSet" to_port="matrix"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Matrix to ExampleSet (2)" to_port="matrix"/>
          <connect from_op="Multiply" from_port="output 3" to_op="Matrix to ExampleSet (3)" to_port="matrix"/>
          <connect from_op="Matrix to ExampleSet (3)" from_port="example set" to_port="result 3"/>
          <connect from_op="Matrix to ExampleSet" from_port="example set" to_port="result 1"/>
          <connect from_op="Matrix to ExampleSet (2)" from_port="example set" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
          <portSpacing port="sink_result 4" spacing="0"/>
        </process>
      </operator>
    </process>
    OP
    Accepted Answer
    wow, thats fast reply! :) Thanks!
