🎉Community Raffle - Win $25
Join and Win
Snowflake JDBC connection help with RM Studio
User: "CarlP"
New Altair Community Member
Updated by Jocelyn
Hi has anyone managed to connect RM studio 9.10 to Snowflake using JDBC? No matter what I try I can't seem to get this working. The instructions in the link below dont work and dont apply to v9.10 of RM
docs.rapidminer.com/latest/studio/connect/database/jdbc/
I would truly appreciate some help with this. thanks Carl
1 - 13 of 131
    User: "bpimper"
    Hi @CarlP,
    What exact settings did You tried to establish the connection?
    I suggest to use a configuration like that:
    After these setting you should provide the JDBC driver Jar file under the Driver tab.
    Make sure you have installed Java 1.8 or higher on your local machine, due to this is a requirement for the Snowflake JDBC driver.
    I hope this will help you out!
    Cheers,
    Bence
    User: "CarlP"
    OP
    Updated by CarlP
    User: "bpimper"
    Hello @CarlP
    Based on Snowflake documentation the URL should look like that: jdbc:snowflake://<account_identifier>.domain.com/?<connection_params> , i suggest to modify the host and remove the snowflake:// part from that.
    Cheers,
    Bence
    User: "CarlP"
    OP
    Updated by CarlP
    User: "bpimper"
    Based on the documentation the host url in this case should look like this: jea45817.us-east-1.snowflakecomputing.com , please remove the othe parts of the url.
    User: "CarlP"
    OP
    RapidMiner 9.10.008  How to successfully connect using the Snowflake JDBC Driver. The 2 snapshots below show the proper way to configure RM 9.10 to Snowflake.
    User: "CarlP"
    OP
    snowflake connection success
    User: "shanila"
    I am getting the error No sutitable driver found for
    User: "jwpfau"
    Altair Employee
    Hi shanila,
    please make sure that the URL prefix is jdbc:snowflake://
    See also this thread https://community.rapidminer.com/discussion/56737/how-to-resolve-no-suitable-driver-found-for-jdbc-snowflake-url-issue-when-connecting-to-snowflake
    Greetings,
    Jonas
    User: "shanila"
    now i am getting a different error which is a number. !390190!
    User: "jwpfau"
    Altair Employee
    That's an Snowflake error code, does your Snowflake server require SAML / SSO?
    You could try to add &authenticator=externalbrowser to the JDBC URL
    Or check the ~/.RapidMiner/rapidminer-studio.log file for more details.
    User: "shanila"
    Unfortunately i cant find log files :(
    or am i looking in a wrong folder?
    we have a trial version
    we dont use SAML/SSO
    this is how i connected
    snowflake://abc.snowflakecomputing.com/?authenticator=externalbrowser&user=abc
    User: "shanila"
    Accepted Answer
    it worked after removing authenticator=externalbrowser&user=abc
