Wrong data applying
1 - 3 of
31
Hi @NgocNguyen2001,
please check that you haven't missing values in any example in your attributes.
If you have missing values in any example of your attributes this option will ignore all of them.
Best,
Cesar
Best,
Cesar
If you select subset or single in "attribute filter type" you need to provide the attributes that you want to consider
Is that your case?
Best
