Is it possible in Simlab 2018 to go through all the elements with a bad quality one by one in the GUI, just the same way as Patch checker in Hypermesh?
Currently we don't have similar command like a patch checker in SimLab. However, the existing way of correcting element quality in SimLab is efficient for most of the application.You can refer below video for element cleanup from Simlab learning center.
Altair for SimLab Learning Center
