🎉Community Raffle - Win $25
Join and Win
Replacing Miscoded Values/terms
User: "jla"
New Altair Community Member
Updated by Jocelyn
Hi! My data set should only include these entries: Positive and Negative. However, there are miscoded entries such as Neg, NEG, and Pos. I tried the "Replace" operator for a couple of times now but some correct entries change too. For instance, I want to change Neg to Negative, the entries with the correct word Negative become Negativeative. How can I correct this?
1 - 4 of 41
    User: "jla"
    OP
    I think I just figured it out right now, but I still don't know if it's right. I used the "multiple arbitrary characters" and it worked for me though I'm not sure if it really is the correct way to do it.
    User: "jla"
    OP
    The second process I used is just the regular expression "negativeative" and it also worked somehow. I viewed their differences in the results and they don't have any so far. Which method do you think is more appropriate to use?
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi!
    ^neg.* would be a good expression, especially if you switch on case-insensitive matching.
    ^ means "beginning of the string". This makes sure that your text starts with "neg". The .* after it is "any sequence of characters". This will match neg, negative, negativeative etc.
    Replace is good for replacing text that you can express as a regular expression. If you have a list of values, Map can be easier to use without regular expressions.
    Regards,
    Balázs
    User: "jla"
    OP
    Just tried it on my previous processes and it worked! Thank you so much @BalazsBarany ! :smiley:
