🎉Community Raffle - Win $25
Join and Win
Append url parameter using loop
User: "ecdbert"
New Altair Community Member
Updated by Jocelyn
I'm sure this has been answered somewhere before.  I'm using the "Read HTML Tables' operator to scrape a table from a website.  However the data is across webpages that end with the page number, such as ?page=2.  How do I create a loop that changes the last digit with each step, using the "Loop Parameters" operator?
1 - 2 of 21
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    you can use the normal loop, which exposes a macro called iteration. you can then use
    ...?page=%{iteration}
    in your operator and are good to go. %{iteration} will be replaced by 1,2,3,4,5 etc.
    Only if you have more complex things to loop over you need to use for example Loop Values and loop over a predefined list of values.
    Best,
    Martin
    User: "ecdbert"
    OP
    Perfect!  Thanks much
