🎉Community Raffle - Win $25
Join and Win
Extract regression equation
User: "Louie"
New Altair Community Member
Updated by Jocelyn
Hi,
I'm building a model to predict a numeric continuous variable by using another numeric variable.
Logarithmic or polynomial equations better fit my data. They have given a lower error rate than linear regression, but I'm unsure how to extract the model equation (formula) from the model I built.
Here is the algorithm I used:
- Generalized Linear Model
- family: gaussian
- link: log
 (Green label = prediction)
Also, I am trying to use polynomial regression for my model since it shows the equation in the model output. However, the prediction is totally off, not sure if I made any mistake in the setting. (Green label = prediction)
Thanks,
1 - 5 of 51
    User: "Caperez"
    Hi @Louie
    There is a good guide about the use and interpretation of GLM. It was very useful for me.
    https://statisticsbyjim.com/regression/interpret-coefficients-p-values-regression/
    Best,
    Cesar
    User: "Louie"
    OP
    Updated by Louie
    Hi ceaperez,
    Thank you for the reference.
    I understand the GLM formula and interpretation. However, I'm not sure where to find the model equation I built which I am planning to apply the model into other application (by using the formula) to predict new testing data (e.g., label = a + b(x) + c (x)   or label = a+b log (x)
    . Also, I am wondering if the rapidminer GLM could automatically generate interaction terms when I have 2 or more numeric or binomial independent variables?
    Thanks,
    Hi,
    maybe you want to check the Function Fitting operator.
    cheers,
    Martin
    User: "Louie"
    OP
    Thanks mschmitz,
    The Function Fitting operator could help me for generating interaction terms.
    However. I'm still not sure how to directly out up the equation from an GLM .
    For example, I can find the equation directly from linear or polynomials model
    but not with GLM
    User: "Caperez"
    Accepted Answer
    Hi @Louie
    If you click on the data option into the left menu, you can see a table with the attributes and coefficients. You can construct the model with the more significant variables using the p-value  and significance level as  criteria.
    The attached image is from sample process for GLM regression.
    Best,
    Cesar
