🎉Community Raffle - Win $25
Join and Win
Add leading zeros if length = 4
User: "syazwaan"
New Altair Community Member
Updated by Jocelyn
I have a dataset something like this:
I want to add leading 0 if the length of data in column_1 is 4 and return in a new column. So that all data in the new column will be the length of 5.
Expected output:
Thank you.
1 - 2 of 21
    User: "Caperez"
    Hi @syazwaan
    A possible solution is work with a nominal data and logic if rule.
    please find attached a simple sample.
    Best
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi!
    If the data are numeric, you can use Format Numbers with a pattern of 00000. This will convert the numbers to a nominal column with the specified format that includes the leading zero if necessary. This would also work for smaller numbers.
    Regards,
    Balázs
