Add leading zeros if length = 4
syazwaan
I have a dataset something like this:
I want to add leading 0 if the length of data in column_1 is 4 and return in a new column. So that all data in the new column will be the length of 5.
Expected output:
Thank you.
Generate Attributes
BalazsBaranyRM
Hi!
If the data are numeric, you can use Format Numbers with a pattern of 00000. This will convert the numbers to a nominal column with the specified format that includes the leading zero if necessary. This would also work for smaller numbers.
Balázs
Caperez
Hi
@syazwaan
A possible solution is work with a nominal data and logic if rule.
please find attached a simple sample.
Best
comp data.rmp
BalazsBaranyRM
Hi!
Balázs
