Altair RISE
Nominate Yourself Now!
Cannot save Process in Rapidminer
User: "manojkumartps"
New Altair Community Member
Updated by Jocelyn
I have reinsatlled Rapidminer 8 since I have cloned my hard disk to a new one. I am able to import excel data perfectly well
However when I started to save my process , it say cannot save process at //Repository/xx . After reading help articles in the forum . I deleted old instance of C:/User/Rapidminer . Did a fresh install but still the problem remained
Next I created a fresh repository folder and tried saving but the same error keep popping up. I am dissapointed since I use rapidminer regularly
Below is the error log. Data1 is the subfolder in my NewLocal repository.
  • Exception: java.io.IOException
  • Message: Cannot store process at //NewLocalRepository/Data1/p: Cannot write C:\Users\UserName\.RapidMiner\repositories\NewLocalRepository\Data1\p.rmp: java.io.FileNotFoundException: Entry 'p.rmp' at location '{1}' contains characters which cannot be stored on some filesystems and are therefore illegal.
  • Stack trace:
  • com.rapidminer.RepositoryProcessLocation.store(RepositoryProcessLocation.java:161)
  • com.rapidminer.Process.save(Process.java:1450)
  • com.rapidminer.gui.actions.SaveAction$1.run(SaveAction.java:124)
  • com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:550)
  • java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
  • java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
  • java.lang.Thread.run(Thread.java:748)
  • Cause
  • Exception: com.rapidminer.repository.RepositoryException
  • Message: Cannot write C:\Users\UserName\.RapidMiner\repositories\NewLocalRepository\Data1\p.rmp: java.io.FileNotFoundException: Entry 'p.rmp' at location '{1}' contains characters which cannot be stored on some filesystems and are therefore illegal.
  • Stack trace:
  • com.rapidminer.repository.local.SimpleProcessEntry.storeXML(SimpleProcessEntry.java:57)
  • com.rapidminer.repository.local.SimpleFolder.createProcessEntry(SimpleFolder.java:341)
  • com.rapidminer.RepositoryProcessLocation.store(RepositoryProcessLocation.java:125)
  • Cause
  • Exception: java.io.FileNotFoundException
  • Message: Entry 'p.rmp' at location '{1}' contains characters which cannot be stored on some filesystems and are therefore illegal.
  • Stack trace:
  • com.rapidminer.tools.Tools.writeTextFile(Tools.java:1195)
  • com.rapidminer.repository.local.SimpleProcessEntry.storeXML(SimpleProcessEntry.java:55)
1 - 7 of 71
    Hi,
    the process is named p: It is not allowed to use :  in process names, simply because windows doesn't like it.
    BR,
    Martin
    OP
    Hi
    There is no : sign there...I have just put "p" . Have tried with other names too...it didn't work
    Okay,
    do you have write access to the folder you are writing to?
    BR,
    Martin
    OP
    Hi Martin...
    The  folde under username has all permissions
    Hi,
    RM tries to write to C:\Users\UserName\.RapidMiner not C:\Users\Manoj\.RapidMiner
    Can you please check?
    Best,
    Martin
    OP
    No Martin.. I am sorry but I though I will mask my name   :)
    So that's why replaced it..In the snapshot it is as is configured
    OP
    Pls somebody help...I am at my wits end
