Bug in tutorial process in Execute Python Operator
Hi there.
I'm trying the tutorial process "Creating a chart using Python and storing it in your repository", because I need to extract some charts from the Python package, but when I try to run the tutorial process, the process stops and shows a "Parsing failed. ". message. This is because the pandas.io.data package used in this script was removed, and Pandas now uses the pandas_datareader package to access remote data such as Yahoo, Google Analytics, etc.
Best,
Cesar
Best,
Cesar
1 - 1 of
11
1 - 1 of
11
Hey @ceaperez,
Thanks for looking into this!
I believe the tutorial has already been updated with the code below.
On the other hand, there is now a URL error after using the correct package, let's see if we need to updated that.
Best,
Peter
try: from pandas.io.data import DataReader except: from pandas_datareader import DataReader
Best,
Peter
Best,
Peter
