🎉Community Raffle - Win $25
Join and Win
Image Handling - Plot an Image
User: "btibert"
New Altair Community Member
Updated by Jocelyn
Is it possible to plot an image to the Results view, especially in the context of the Image Handling Extension?  I know that there is an option to Store the Image to a file system, but my ask is to plot the image within the process > Results.
My use cases:
- Teaching to show an image is just a dataset.  This is particularly helpful when extending the concept of data shapes outside of tabular 2D datasets.
- After fitting an image classification model, it would be nice to be able to review the predicted labels (e.g. MNIST) with the actual image classified for visual inspection.  Perhaps a 3 was misclassified as a 9, and this feature would allow us to visually review how these networks learn (or fail).
1 - 4 of 41
    User: "Caperez"
    Hi @btibert
    To handle with this situation I use to proceed as follows.
    1- Multiply the output of the Read Image Metadata operator that goes to Apply Model operator.
    2- Inner Join of Path from Perform operator and Read Image Metadata.
    3- Apply a Read Image as Exampleset operator to testing images.
    4- Plot images in Visualization Module as Heatmaps using all the attibutes.
    Best,
    Cesar
    User: "btibert"
    OP
    Thanks!  I didn't think about Read Image as ExampleSet, and that is a nice hack.  With that said, I am not 100% certain I follow the flow above. Any chance you could diagram that out?
    Also, when using Read Image As ExampleSet, it doesn't appear that we can do any image pre-processing unless I am missing a Tensor to ExampleSet conversion operator.  For example my images need to be rotated.
    Thanks again.  I am trying to map how I do certain tasks in python within RM (either base or Extensions) and avoid using Execute Python as much as possible.
    User: "Caperez"
    Accepted Answer
    Hi @btibert
    please find attached an image of sample process for MNIST dataset.
    1- Inside to the Pre-Process Image operator you can create a flows with operators for image preprocessing: crop, rotate, flip, resize.
    2- To be able to compare the the predicted label and the current label, I use to joint the Exa output of the Perform Operator with a copy of the outuput of the Read Image Metadata Operator used for testing dataset.
    I hope you find this flow clearest than the previous one.
    Best,
    Cesar
    User: "btibert"
    OP
    Thank you
