Image Handling - Plot an Image
btibert
Is it possible to plot an image to the Results view, especially in the context of the Image Handling Extension? I know that there is an option to Store the Image to a file system, but my ask is to plot the image within the process > Results.
My use cases:
- Teaching to show an image is just a dataset. This is particularly helpful when extending the concept of data shapes outside of tabular 2D datasets.
- After fitting an image classification model, it would be nice to be able to review the predicted labels (e.g. MNIST) with the actual image classified for visual inspection. Perhaps a 3 was misclassified as a 9, and this feature would allow us to visually review how these networks learn (or fail).
Caperez
Hi
@btibert
please find attached an image of sample process for MNIST dataset.
1- Inside to the Pre-Process Image operator you can create a flows with operators for image preprocessing: crop, rotate, flip, resize.
2- To be able to compare the the predicted label and the current label, I use to joint the Exa output of the Perform Operator with a copy of the outuput of the Read Image Metadata Operator used for testing dataset.
I hope you find this flow clearest than the previous one.
Best,
Cesar
Caperez
Hi
@btibert
To handle with this situation I use to proceed as follows.
1- Multiply the output of the Read Image Metadata operator that goes to Apply Model operator.
2- Inner Join of Path from Perform operator and Read Image Metadata.
3- Apply a Read Image as Exampleset operator to testing images.
4- Plot images in Visualization Module as Heatmaps using all the attibutes.
Best,
Cesar
btibert
Thanks! I didn't think about Read Image as ExampleSet, and that is a nice hack. With that said, I am not 100% certain I follow the flow above. Any chance you could diagram that out?
Also, when using Read Image As ExampleSet, it doesn't appear that we can do any image pre-processing unless I am missing a Tensor to ExampleSet conversion operator. For example my images need to be rotated.
Thanks again. I am trying to map how I do certain tasks in python within RM (either base or Extensions) and avoid using Execute Python as much as possible.
Caperez
Hi
@btibert
Best,
Cesar
btibert
Thank you
