generate a new (complex) Attribute
Hey everyone,
I want to get a new attribute which is quiet complicated (atleast I think its the case)
I got the follwoing table with the data set in black and I want to get a new variable which indicates if the last case (look at date) with the same ID was a yes or no.
Imagine the data would be if a person (ID) came to the doctors appionted was noted. Now I want to generate an attribute if the person (ID) came to the last appointment (before this one)or not. How can I enable this in Rapidminer because its quiet complex for me. Hope you get my question with the example
1 - 3 of
31
Hi,
seems like you can first use lag and then something like:
with generate attributes
or so?
Best,
Martin
