<?xml version="1.0" encoding="UTF-8"?><process version="9.10.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.10.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.10.001" expanded="true" height="68" name="Retrieve Golf" origin="GENERATED_TUTORIAL" width="90" x="112" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Golf"/><br> </operator><br> <operator activated="true" class="multiply" compatibility="9.10.001" expanded="true" height="103" name="Multiply" width="90" x="246" y="34"/><br> <operator activated="true" class="h2o:logistic_regression" compatibility="9.10.001" expanded="true" height="124" name="Logistic Regression" width="90" x="380" y="34"><br> <parameter key="solver" value="AUTO"/><br> <parameter key="reproducible" value="false"/><br> <parameter key="maximum_number_of_threads" value="4"/><br> <parameter key="use_regularization" value="false"/><br> <parameter key="lambda_search" value="false"/><br> <parameter key="number_of_lambdas" value="0"/><br> <parameter key="lambda_min_ratio" value="0.0"/><br> <parameter key="early_stopping" value="true"/><br> <parameter key="stopping_rounds" value="3"/><br> <parameter key="stopping_tolerance" value="0.001"/><br> <parameter key="standardize" value="true"/><br> <parameter key="non-negative_coefficients" value="false"/><br> <parameter key="add_intercept" value="true"/><br> <parameter key="compute_p-values" value="true"/><br> <parameter key="remove_collinear_columns" value="true"/><br> <parameter key="missing_values_handling" value="MeanImputation"/><br> <parameter key="max_iterations" value="0"/><br> <parameter key="max_runtime_seconds" value="0"/><br> </operator><br> <operator activated="true" class="blending:set_positive_value" compatibility="9.10.001" expanded="true" height="82" name="Set Positive Value" origin="GENERATED_TUTORIAL" width="90" x="380" y="238"><br> <parameter key="positive_values" value="Play␝no"/><br> </operator><br> <operator activated="true" class="apply_model" compatibility="9.10.001" expanded="true" height="82" name="Apply Model" width="90" x="514" y="34"><br> <list key="application_parameters"/><br> <parameter key="create_view" value="false"/><br> </operator><br> <operator activated="true" class="performance" compatibility="9.10.001" expanded="true" height="82" name="Performance" width="90" x="648" y="34"><br> <parameter key="use_example_weights" value="true"/><br> </operator><br> <operator activated="true" class="h2o:logistic_regression" compatibility="9.10.001" expanded="true" height="124" name="Logistic Regression (2)" width="90" x="514" y="238"><br> <parameter key="solver" value="AUTO"/><br> <parameter key="reproducible" value="false"/><br> <parameter key="maximum_number_of_threads" value="4"/><br> <parameter key="use_regularization" value="false"/><br> <parameter key="lambda_search" value="false"/><br> <parameter key="number_of_lambdas" value="0"/><br> <parameter key="lambda_min_ratio" value="0.0"/><br> <parameter key="early_stopping" value="true"/><br> <parameter key="stopping_rounds" value="3"/><br> <parameter key="stopping_tolerance" value="0.001"/><br> <parameter key="standardize" value="true"/><br> <parameter key="non-negative_coefficients" value="false"/><br> <parameter key="add_intercept" value="true"/><br> <parameter key="compute_p-values" value="true"/><br> <parameter key="remove_collinear_columns" value="true"/><br> <parameter key="missing_values_handling" value="MeanImputation"/><br> <parameter key="max_iterations" value="0"/><br> <parameter key="max_runtime_seconds" value="0"/><br> </operator><br> <operator activated="true" class="apply_model" compatibility="9.10.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="648" y="238"><br> <list key="application_parameters"/><br> <parameter key="create_view" value="false"/><br> </operator><br> <operator activated="true" class="performance" compatibility="9.10.001" expanded="true" height="82" name="Performance (Set Pos)" width="90" x="782" y="238"><br> <parameter key="use_example_weights" value="true"/><br> </operator><br> <connect from_op="Retrieve Golf" from_port="output" to_op="Multiply" to_port="input"/><br> <connect from_op="Multiply" from_port="output 1" to_op="Logistic Regression" to_port="training set"/><br> <connect from_op="Multiply" from_port="output 2" to_op="Set Positive Value" to_port="example set input"/><br> <connect from_op="Logistic Regression" from_port="model" to_op="Apply Model" to_port="model"/><br> <connect from_op="Logistic Regression" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/><br> <connect from_op="Set Positive Value" from_port="example set output" to_op="Logistic Regression (2)" to_port="training set"/><br> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/><br> <connect from_op="Performance" from_port="performance" to_port="result 1"/><br> <connect from_op="Logistic Regression (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/><br> <connect from_op="Logistic Regression (2)" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/><br> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (Set Pos)" to_port="labelled data"/><br> <connect from_op="Performance (Set Pos)" from_port="performance" to_port="result 2"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> <portSpacing port="sink_result 3" spacing="0"/><br> </process><br> </operator><br></process><br><br>
