🎉Community Raffle - Win $25
Join and Win
Load data from InfluxDB into RapidMiner
User: "moritz27"
New Altair Community Member
Updated by Jocelyn
Hello all,
i need to analyze data stored in a InfluxDB. Sadly there is no JDBC driver for this database. Is there any way to do this anyway?
I have searched the web and this forum without any usefull hint.
Any help is appreciated!
Best regards and thanks in advance :smile:
1 - 9 of 91
    Hi @mortiz,
    It seems you can connect to it via API
    https://docs.influxdata.com/influxdb/v1.8/tools/api/
    For this you can download the WebMining Extension from the marketplace and use the Get Operator or Post depending on what you want to do.
    User: "moritz27"
    OP
    Thanks for your suggestion! Sadly Im not able to install extensions behind proxy, have to fix this first. Will reply if I have more details
    User: "moritz27"
    OP
    Hello again,
    I managed to install the extension manualy but sadly I'm not able to query the DB. I get the following error:   "REST service could not be asccessed". When i try the same query from the same machine from CMD I get the expected result.
    I tried the "/health HTTP endpoint" from the link you provided for the influxDB API: "curl -XGET "192.168.132.210:8086/health"
    Any ideas?
    User: "Aion"
    Hello all,
    I need load data from influxDb with rapidminer set up connection jdbc follow Image capture?
    Hi @Aion,
    Could you please post a screenshot of your driver tab as well?
    Best,
    Roland
    User: "Aion"
    Hi @rjones13
    screenshot  driver is empty
    Best,
    Aion
    Hi @Aion,
    If you're not using one of our pre-built connections, you'll need to add the driver yourself. This webpage should help: https://docs.rapidminer.com/latest/studio/connect/database/jdbc/
    Best,
    Roland
    User: "Aion"
    Hi @rjones13
    Case use influxDb.
    If driver have follow picture.
    Please recommend file.jar download or choose file.jar.
    Best,
    Aion
    Hi @Aion,
    I would look via a search engine for "InfluxDB JDBC driver", such as: https://dbschema.com/jdbc-driver/influxdb.html
    Then follow the steps above.
    Best,
    Roland
